CircuitPython Hackaday portal using M4, ESP32...
20skulls.JPG20 skulls!JPEG Image - 2.31 MB - 01/14/2019 at 21:54 |
checkbook.zipfont usedZip Archive - 19.42 kB - 01/14/2019 at 18:32 |
adafruit_2018_1201.jpgimage on deviceJPEG Image - 408.43 kB - 01/14/2019 at 03:55 |
update, optimized code, added more things it can do... and more! video:
This example will access an API, grab a number like hackaday skulls, github
stars, price of bitcoin, twitter followers... and display it on a screen if you can find something that
spits out JSON data, we can display it!
import gc
import time
import board
import busio
import microcontroller
from digitalio import DigitalInOut, Direction
from Adafruit_CircuitPython_ESP_ATcontrol import adafruit_espatcontrol
from Adafruit_CircuitPython_BitmapFont.adafruit_bitmap_font import bitmap_font
from Adafruit_CircuitPython_Display_Text.adafruit_display_text.text_area import TextArea
import ujson
import neopixel
import displayio
import pulseio
backlight = pulseio.PWMOut(board.TFT_BACKLIGHT)
splash = displayio.Group()
board.DISPLAY.show(splash)
# open background file and show it
f = open("background.bmp", "rb")
background = displayio.OnDiskBitmap(f)
face = displayio.Sprite(background, pixel_shader=displayio.ColorConverter(), position=(0,0))
splash.append(face)
board.DISPLAY.wait_for_frame()
# turn on backlight
backlight.duty_cycle = 2**15
# load font
font = bitmap_font.load_font("fonts/Checkbook-25.bdf")
text = None
def set_message(string):
global text
if text:
splash.pop()
text = TextArea(font, text=string)
text.y = 280
splash.append(text.group)
gc.collect()
set_message("SKULL VIEW!")
# Get wifi details and more from a settings.py file
try:
from settings import settings
except ImportError:
print("WiFi settings are kept in settings.py, please add them there!")
raise
set_message("SETTINGS OK")
# CONFIGURATION
PLAY_SOUND_ON_CHANGE = True
NEOPIXELS_ON_CHANGE = False
TIME_BETWEEN_QUERY = 15 # in seconds
# Some data sources and JSON locations to try out
DATA_SOURCE = "https://api.hackaday.io/v1/projects/163309?api_key="+settings['hackaday_token']
DATA_LOCATION = ["skulls"]
set_message("INIT ESP32")
uart = busio.UART(microcontroller.pin.PB12, microcontroller.pin.PB13, timeout=0.1)
resetpin = DigitalInOut(board.ESP_RESET)
rtspin = DigitalInOut(board.ESP_BUSY)
# Create the connection to the co-processor and reset
esp = adafruit_espatcontrol.ESP_ATcontrol(uart, 115200, run_baudrate=921600,
reset_pin=resetpin,
rts_pin=rtspin, debug=True)
esp.hard_reset()
status = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.2)
# neopixels
if NEOPIXELS_ON_CHANGE:
pixels = neopixel.NeoPixel(board.A1, 16, brightness=0.4, pixel_order=(1, 0, 2, 3))
pixels.fill(0)
# music!
if PLAY_SOUND_ON_CHANGE:
import audioio
wave_file = open("coin.wav", "rb")
wave = audioio.WaveFile(wave_file)
# we'll save the value in question
last_value = value = 0
the_time = None
times = 0
def chime_light():
"""Light up LEDs and play a tune"""
for i in range(0, 100, 10):
pixels.fill((i, i, i))
starpin.value = True
with audioio.AudioOut(board.A0) as audio:
audio.play(wave)
while audio.playing:
pass
starpin.value = False
for i in range(100, 0, -10):
pixels.fill(0)
def get_value(response, location):
"""Extract a value from a json object, based on the path in 'location'"""
try:
print("Parsing JSON response...", end='')
json = ujson.loads(response)
print("parsed OK!")
for x in location:
json = json[x]
return json
except ValueError:
print("Failed to parse json, retrying")
return None
while True:
try:
status[0] = (0,0,100)
while not esp.is_connected:
# settings dictionary must contain 'ssid' and 'password' at a minimum
set_message("ESP32 CONNECTING...")
status[0] = (100, 0, 0) # red = not connected
esp.connect(settings)
set_message("ESP32 CONNECTED!")
# great, lets get the data
# get the time
#the_time = esp.sntp_time
print("Retrieving data source...", end='')
status[0] = (100, 100, 0) # yellow = fetching data
header, body = esp.request_url(DATA_SOURCE)
status[0] = (0, 0, 100) # green = got data
print("Reply is OK!")
except (RuntimeError, adafruit_espatcontrol.OKError) as e:
print("Failed to get data, retrying\n", e)
continue
#print('-'*40, "Size: ", len(body))
#print(str(body, 'utf-8'))
#print('-'*40)
value = get_value(body, DATA_LOCATION)
if value is None:
continue
print(times, the_time, "value:", value)
set_message(" SKULLS: %d" % value)
times += 1
# normally we wouldn't have to do this, but we get bad fragments
header = body = None
gc.collect()
print(gc.mem_free()) # pylint: disable=no-member
time.sleep(TIME_BETWEEN_QUERY)
movin' locations, updated! https://github.com/ladyada/CircuitPython-WiFi-Demos/blob/master/skulls/skull.py
we are up to 20 skulls! https://twitter.com/adafruit/status/1084931230414581761
Love seeing the classic Hackaday font (Checkbook ttf if anyone's wondering).
phryk
Jonathan Rowny
Dave Bennett
TingoGO
Fun project!
I see the code is here in the instructions, but the link to the GitHub project repo is 404, just FYI.
