CircuitPython Hackaday portal - PyPortal
CircuitPython Hackaday portal using M4, ESP32...
ptpt
Public Chat
CircuitPython Hackaday portal using M4, ESP32... PyPortal
20 skulls!
JPEG Image - 2.31 MB - 01/14/2019 at 21:54
Preview
checkbook.zip
font used
Zip Archive - 19.42 kB - 01/14/2019 at 18:32
Download
image on device
JPEG Image - 408.43 kB - 01/14/2019 at 03:55
Preview
View project log
  • 1
    CircuitPython code
    This example will access an API, grab a number like hackaday skulls, github
    stars, price of bitcoin, twitter followers... and display it on a screen if you can find something that
    spits out JSON data, we can display it!
    import gc
    import time
    import board
    import busio
    import microcontroller
    from digitalio import DigitalInOut, Direction
    from Adafruit_CircuitPython_ESP_ATcontrol import adafruit_espatcontrol
    from Adafruit_CircuitPython_BitmapFont.adafruit_bitmap_font import bitmap_font
    from Adafruit_CircuitPython_Display_Text.adafruit_display_text.text_area import TextArea
    import ujson
    import neopixel
    import displayio
    import pulseio
    backlight = pulseio.PWMOut(board.TFT_BACKLIGHT)
    splash = displayio.Group()
    board.DISPLAY.show(splash)
    # open background file and show it
    f = open("background.bmp", "rb")
    background = displayio.OnDiskBitmap(f)
    face = displayio.Sprite(background, pixel_shader=displayio.ColorConverter(), position=(0,0))
    splash.append(face)
    board.DISPLAY.wait_for_frame()
    # turn on backlight
    backlight.duty_cycle = 2**15
    # load font
    font = bitmap_font.load_font("fonts/Checkbook-25.bdf")
    text = None
    def set_message(string):
        global text
        if text:
            splash.pop()
        text = TextArea(font, text=string)
        text.y = 280
        splash.append(text.group)
        gc.collect()
    set_message("SKULL VIEW!")
    # Get wifi details and more from a settings.py file
    try:
        from settings import settings
    except ImportError:
        print("WiFi settings are kept in settings.py, please add them there!")
        raise
    set_message("SETTINGS OK")
    #              CONFIGURATION
    PLAY_SOUND_ON_CHANGE = True
    NEOPIXELS_ON_CHANGE = False
    TIME_BETWEEN_QUERY = 15  # in seconds
    # Some data sources and JSON locations to try out
    DATA_SOURCE = "https://api.hackaday.io/v1/projects/163309?api_key="+settings['hackaday_token']
    DATA_LOCATION = ["skulls"]
    set_message("INIT ESP32")
    uart = busio.UART(microcontroller.pin.PB12, microcontroller.pin.PB13, timeout=0.1)
    resetpin = DigitalInOut(board.ESP_RESET)
    rtspin = DigitalInOut(board.ESP_BUSY)
    # Create the connection to the co-processor and reset
    esp = adafruit_espatcontrol.ESP_ATcontrol(uart, 115200, run_baudrate=921600,
                                              reset_pin=resetpin,
                                              rts_pin=rtspin, debug=True)
    esp.hard_reset()
    status = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.2)
    # neopixels
    if NEOPIXELS_ON_CHANGE:
        pixels = neopixel.NeoPixel(board.A1, 16, brightness=0.4, pixel_order=(1, 0, 2, 3))
        pixels.fill(0)
    # music!
    if PLAY_SOUND_ON_CHANGE:
        import audioio
        wave_file = open("coin.wav", "rb")
        wave = audioio.WaveFile(wave_file)
    # we'll save the value in question
    last_value = value = 0
    the_time = None
    times = 0
    def chime_light():
        """Light up LEDs and play a tune"""
            for i in range(0, 100, 10):
                pixels.fill((i, i, i))
        starpin.value = True
            with audioio.AudioOut(board.A0) as audio:
                audio.play(wave)
                while audio.playing:
                    pass
        starpin.value = False
            for i in range(100, 0, -10):
            pixels.fill(0)
    def get_value(response, location):
        """Extract a value from a json object, based on the path in 'location'"""
        try:
            print("Parsing JSON response...", end='')
            json = ujson.loads(response)
            print("parsed OK!")
            for x in location:
                json = json[x]
            return json
        except ValueError:
            print("Failed to parse json, retrying")
            return None
    while True:
        try:
            status[0] = (0,0,100)
            while not esp.is_connected:
                # settings dictionary must contain 'ssid' and 'password' at a minimum
                set_message("ESP32 CONNECTING...")
                status[0] = (100, 0, 0) # red = not connected
                esp.connect(settings)
                set_message("ESP32 CONNECTED!")
            # great, lets get the data
            # get the time
            #the_time = esp.sntp_time
            print("Retrieving data source...", end='')
            status[0] = (100, 100, 0)   # yellow = fetching data
            header, body = esp.request_url(DATA_SOURCE)
            status[0] = (0, 0, 100)   # green = got data
            print("Reply is OK!")
        except (RuntimeError, adafruit_espatcontrol.OKError) as e:
            print("Failed to get data, retrying\n", e)
            continue
        #print('-'*40, "Size: ", len(body))
        #print(str(body, 'utf-8'))
        #print('-'*40)
        value = get_value(body, DATA_LOCATION)
        if value is None:
            continue
        print(times, the_time, "value:", value)
        set_message("       SKULLS: %d" % value)
        times += 1
        # normally we wouldn't have to do this, but we get bad fragments
        header = body = None
        gc.collect()
        print(gc.mem_free())  # pylint: disable=no-member
        time.sleep(TIME_BETWEEN_QUERY)
View all instructions
Ted Yapo wrote 01/16/2019 at 14:16 point
Fun project!
I see the code is here in the instructions, but the link to the GitHub project repo is 404, just FYI.
pt wrote 01/14/2019 at 21:52 point
fabian wrote 01/14/2019 at 19:29 point
I prefer ruby
but needed 400kb Ram
Dan Maloney wrote 01/14/2019 at 19:26 point
Hmm... an API for Hackaday.io, you say? BRB...
Mike Szczys wrote 01/14/2019 at 16:27 point
Love seeing the classic Hackaday font (Checkbook ttf if anyone's wondering).
