Delays
02/24/2019 at 00:44 • 0 commentsSo this project is indefinitely delayed due to the tragic death of my beloved fish, Macintosh.
Additionally, the tank I was using lost a battle with a humongous falling mirror.
So with the loss of motivator (macintosh) and main component (tank), I will be focusing my attention elsewhere for the time being. But one day I will avenge Macintosh and build a beautiful gimmicky LED scape for his predecessors.
01/20/2019 at 01:09 • 0 commentsorthographic projections . thumbs up emoji.
For the Command Center
01/18/2019 at 16:48 • 0 commentsStream interaction & input.
STREAM! GET IT! BECAUSE ITS FOR A FISH :D
- Install node.js and npm
- Clone files to computer - https://github.com/hzoo/TwitchPlaysX/archive/master.zip
- Node packages from command line
npm install
in folder (irc, printf)- Install python - http://www.python.org/download/releases/2.7.6/ (make sure python is on PATH)
- Install python win32 package - http://sourceforge.net/projects/pywin32/files/pywin32/
OpenCV : https://opencv.org/
For the Neopixels:
Potential code;
Fader - https://learn.adafruit.com/multi-tasking-the-arduino-part-3/fader
// Initialize for a Fade void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD) { ActivePattern = FADE; Interval = interval; TotalSteps = steps; Color1 = color1; Color2 = color2; Index = 0; Direction = dir; }
This should help make the transitions nice and smooth when Macintosh is moving between quadrants. Fast transitions = jarring = scared fishy.
References:
NeoPixel UberGuide:
https://cdn-learn.adafruit.com/downloads/pdf/adafruit-neopixel-uberguide.pdf
