Test the code
01/18/2019 at 18:46 • 2 commentsThe GxEPD2 offers an example code, but it needs some adjustments:
- You need to change all the "const char" parts of the code to "char".
- You need to comment out the line of the right display around Line 92:
GxEPD2_3C<GxEPD2_750c, GxEPD2_750c::HEIGHT / 4> display(GxEPD2_750c(/*CS=15*/ SS, /*DC=4*/ 4, /*RST=5*/ 5, /*BUSY=16*/ 16));
- The right pin mapping should be adjusted in the same line
GxEPD2_3C<GxEPD2_750c, GxEPD2_750c::HEIGHT / 4> display(GxEPD2_750c(D8, D3, D4, D2));
Upload the code and see the miracle. :D
Wiring it Up
01/18/2019 at 18:38 • 0 commentsThe GxEPD2 Library suggests the following mapping from Waveshare SPI e-Paper to ESP8266 NodeMCU:
- BUSY -> D2
- RST -> D4
- DC -> D3,
- CS -> D8
- CLK -> D5
- DIN -> D7
- GND -> GND
- 3.3V -> 3.3V
It works quite well (with the necessary adjustment in the code)
