CC2531 USB Adapter Antenna mod
Back to overview
How to correctly add an SMA Antenna to your ZigBee Sniffer / Gateway Adapter for increased range
B wrote 04/27/2019 at 22:01 point
I don't quite follow. Is this what you do? https://www.screencast.com/t/sJM3PLoIa
roygbiv856 wrote 01/21/2019 at 02:17 point
What exactly do you mean by "solder the ground trace/bridge on the left side"? Are you talking about this little spot I highlighted where you also removed some solder mask? https://imgur.com/a/nb9MIR8
