The project is still going on. Almost done. A syncable VCO modulated by another VCO have been added and can also module the 4bit converter and the keyer. Quite happy with the results ! Next steps, building a box for it and maybe built a version with a Microprocessor for the additional modulation (and reduce part count).
How many of those PCBs did you get made?
