So some developments. I have finally had a chance to order most of the hardware I'm planning on using. So by Tuesday the wiring and programming can commence. EXPECT REGULAR UPDATES!
In other news I've been looking at resin casting for the components with the goal of making the case as small as possible as well as making the design waterproof, I do plan on running with it after all, so please comment if you have anu thoughts.
Lastly I'm looking at replacing more hardware, to be specific I'm looking at replacing the 0.96" screen with a 0.49 which should reduce the volume dramatically... also the weight. Please see concept for the 0.49" oled:
As always please let me know your thoughts.
