Just a simple update:
I've ordered and received the following
Beetle Bluno Heart Sensor(Yes the name is very creative)
Unfortunately the heart sensor I was sent is a dud and I've contacted the seller (diyelectronics.co.za) and they've been gracious enough to offer a replacement. Hopefully on Monday I will de-solder the dud and soled up the replacement.
I've been using the following script to test the sensor(only get garbage). Hopefully on monday I'll have a working sensor connected and I can start playing around with variables to get an ideal and reliable output.
const int inputPin = A0;
const int threshold = 550;
void setup() {
Serial.begin(115200);
void loop() {
int signal = (analogRead(inputPin));
if (signal > threshold)
Serial.println(signal * 5);
delay(10);
Serial.println(10);
