Hey everyone,
So the next step on the path to CommuteGuardian is a SoM for the Myriad X and the i.MX 8M. This will allow us to drop in a full system running a modern Linux, and with the VPU power of the Myriad X, into our Commute Guardian prototype (and hopefully, final product). The data path is shown below:
And it will allow you to do the same for your application! Think of this as like the 'Pro' version of DepthAI for Raspberry Pi. As it allows it to drop directly into your prototype or product, with the wicked power of the i.MX 8M backing up the visual processing prowess of the Myriad X.
So we just started about a week ago, and here are some layout views to show progress so far:
Thoughts? Questions/ideas/comments welcome!
Cheers,
The Luxonis Team!
Hi, Brandon
Is this project still on-going?
Also update the main page to have this on it:
https://hackaday.io/project/163679/details/
Thoughts?
Thanks,
Brandon
Hey @Tegwyn☠Twmffat ,
Sorry about the delay. Have a block diagram now. So it looks like comments don't support pictures, so link to Google photos for now.
Raspberry Pi Version:
https://lh3.googleusercontent.com/j0-RsdjNVkzw-CgNXeAgKni8RFb643uxsbuJ23ERUEXMXRQ7BMAvhs4GxlH7Lap-Lq35Y9bats6a2jOrHJw_sIoxNv646gY_oItdFMI26k69KrupOoW1IaiUNvZ3TrqVoJ0urCsxwkUkQis_1NtIqpmf8p6usCyXANy-FT6vMOO8r8iy063_uDhAVxKzxRz8mdoetKsIo1RF9SLxpXOVZnZsKDdnfA06xIVykaDSEIKWptC_91mwXfO3Upjsp3hNHizzMqqmI1NF9jgAW-gCbQ8MMXy2NhH8NbbdtspruNU9Zi9BzFvnMhDLr4fXdRejTCL5mtAqgvT1RY9WklNhmOqHWr04Mcn7St0QaBy1kn5vWRygTzltOa-l8KdNOsXBThIKt7GKycl0K22H9uJLlnWQ11wqZeShgzaVgUkDrolYiyv68Bb8hGcB71WGCWmWttsf47LXpqxnh7M6yEMKfDimcnIVR7iOFUpzRxbxsPBmDoB6NlkH6abrMtdUhCz576QYE6t0cEbg1K4oT5W5sYq5S1bggbOWhebs2_0quXJUdP5iSkLqQEWP9XFBd0I9lRyYEd0uWUTTQ7j-cezUkH8WgRvYJFqcfsSP2jiX7j6idvo4Cgi7x1J9zYZHmzMeNImvexDiAqWYU2OQz1XCEZtEE8K9YFcuNVRuv5mryI5h6LLV2X1uH6nr7TZnqeR6QHzit1gNBwOTL6BCmhiJmAoG=w903-h464-no
I'll also reach out over messaging to discuss. And I'm also planning on making a block diagram for the i.MX 8M module version as well (the i.MX 8M replaces the Pi in that version).
Thoughts?
Thanks,
Brandon
Please could you produce some kind of flow chart showing the 3 cameras and where the data from Myriad X goes WRT the carrier board? It's not clear what the i.MX 8M does and how it will communicate with the Pi. Thanks!
