Drawing Machine
A drawing machine created using gears and a 3d printer!
This is a remake of the very classic "drawing machine". This project was made in fusion 360 using the gear function that is included in the program. The hole in the arms that hold the pen are about 10 mm wide so it will fit any pen or pencil of that size.
Finger gear.stl
Standard Tesselated Geometry - 380.75 kB - 02/02/2019 at 18:16
Download
Gear peg (print 2).stl
Standard Tesselated Geometry - 374.59 kB - 02/02/2019 at 18:16
Download
Big gear.stl
Standard Tesselated Geometry - 653.40 kB - 02/02/2019 at 18:16
Download
Arm (print 2).stl
Standard Tesselated Geometry - 425.57 kB - 02/02/2019 at 18:16
Download
Base.stl
Standard Tesselated Geometry - 151.55 kB - 02/02/2019 at 18:16
Download
Alan Green wrote 07/30/2019 at 23:01 point
Beautiful photographs!
Jake wrote 07/31/2019 at 13:45 point
Thank you, Alan! :)
Alexander wrote 02/04/2019 at 19:16 point
I love these circular drawing machines! It teaches you to convert Cartesian to polar, and to think in circles instead of lines. Do you have any plans to build a working system around this design?
Cheers!
Jake wrote 02/05/2019 at 03:12 point
I didnt have plans to but now that you mention it, that sounds like an awesome idea! Thanks! :)
Dan Maloney wrote 02/04/2019 at 16:06 point
I'm trying to figure out what kind of pattern this would make, but my spatial relations are letting me down. Still, looks cool. Might be neat if the two smaller gears up top were a bit larger and had different holes that the pen arms could be plugged into, to vary the pattern.
And thanks for entering the 3D-Printed Gears, Pulleys, and Cams contest!
Jake wrote 02/05/2019 at 03:11 point
thank you for your suggestions! I really appreciate it :) Ill definitely be looking into editing the design and adding some things Ive been suggested :)
