A drawing machine created using gears and a 3d printer!
Finger gear.stlStandard Tesselated Geometry - 380.75 kB - 02/02/2019 at 18:16 |
Gear peg (print 2).stlStandard Tesselated Geometry - 374.59 kB - 02/02/2019 at 18:16 |
Big gear.stlStandard Tesselated Geometry - 653.40 kB - 02/02/2019 at 18:16 |
Arm (print 2).stlStandard Tesselated Geometry - 425.57 kB - 02/02/2019 at 18:16 |
Base.stlStandard Tesselated Geometry - 151.55 kB - 02/02/2019 at 18:16 |
I love these circular drawing machines! It teaches you to convert Cartesian to polar, and to think in circles instead of lines. Do you have any plans to build a working system around this design?
Cheers!
I didnt have plans to but now that you mention it, that sounds like an awesome idea! Thanks! :)
I'm trying to figure out what kind of pattern this would make, but my spatial relations are letting me down. Still, looks cool. Might be neat if the two smaller gears up top were a bit larger and had different holes that the pen arms could be plugged into, to vary the pattern.
And thanks for entering the 3D-Printed Gears, Pulleys, and Cams contest!
thank you for your suggestions! I really appreciate it :) Ill definitely be looking into editing the design and adding some things Ive been suggested :)
Beautiful photographs!
