Top Assembly.stl
The outer shell of the gearbox, that slides into the top of the LampBody.
Standard Tesselated Geometry -
171.47 kB -
02/04/2019 at 03:02
Download
LoxodromeMountingAdapter.stl
The part is the top half of the GearCoreCenter and provides a snap-fit to the Loxodrome.
165.41 kB -
02/04/2019 at 03:02
Download
GearCoreCenter.stl
This part holds the 608 bearing and has the larger 12 toothed gear on the outside. Once the bearing is placed inside, the LoxodromeMountingAdapter is glued into place.
189.93 kB -
02/04/2019 at 03:02
Download
DriveGear.stl
The small six-toothed gear that rotates the GearCoreCenter.
45.59 kB -
02/04/2019 at 03:01
Download
Base Plate.stl
The bottom base piece that holds the motor and sits under the BasePlate.
132.70 kB -
02/04/2019 at 03:01
Download
Motor Adapter.stl
A small adapter that allows the DriveRod to connect to the motor.
85.92 kB -
02/04/2019 at 03:02
Download
DriveRod.stl
A short drive rod that connects the motor to the gearbox. Slides into the Motor Adapter on one end and into the DriveGear on the other.
1.45 kB -
02/04/2019 at 03:01
Download
Loxodrome.stl
The Loxodrome sphere.
6.08 MB -
02/04/2019 at 03:02
Download
LampBody.stl
The outer body of the lamp that sits atop the Base Plate.
534.54 kB -
02/04/2019 at 03:02
Download
LoxodromeLamp.scad
This OpenSCAD file is the original design for the lamp. Only the LampBody and Loxodrome are retained in the new design, all other parts are replaced.
scad -
10.46 kB -
02/04/2019 at 03:02
Download
TheSpiralLamp.FCStd
This is the FreeCAD document with the parts for the replacement gearbox.
fcstd -
4.50 MB -
02/04/2019 at 03:02
Download
