Split-flap display
A 3d printed split-flap display using a 28byj-48 stepper motor
A 3d printed 12 digit split-flap display using a 28byj-48 stepper motor. The motor was moved to the back to provide a slimmer profile. A 3d printer endstop module is used to check for the position of the drum with each rotation.
Several of these modules can be put together for a clock or counter
The current display has 12 flaps, meaning 10 numbers, a blank face and one other character.
The mechanical part of this project is finished, next up is code and electronics in order to create a clock out of these. The plan is to modify these cheap steppers to a bipolar layout, seen here. And then use off the shelf electronics used in cheap cnc/3dprinter/plotter such as these or just plain stepsticks.
Since I've entered this in the 3d printed gears contest, I'll mention that the gears used to drive the mechanism were generated using Fusion 360's build in gear generator. I've used this generator in multiple projects and can recommend it to easily generate simple spur gears.
spacer.stl
simplify3d_stl - 56.04 kB - 02/06/2019 at 15:51
Download
motormount.stl
simplify3d_stl - 72.54 kB - 02/06/2019 at 15:51
Download
drivegear.stl
simplify3d_stl - 474.98 kB - 02/03/2019 at 19:29
Download
drum2.stl
simplify3d_stl - 303.60 kB - 02/03/2019 at 19:29
Download
drumgear.stl
simplify3d_stl - 318.54 kB - 02/03/2019 at 19:29
Download
View all 9 files
  • 1 × 28byj-48
  • 2 × 625zz bearing
  • 1 × mechanical endstop
View project log
goguelnikov wrote 08/19/2024 at 20:46 • point
Hello Jones,
Nice work. Could you please share the source file for this model? I would love to be able to modify it by incresing the number of flaps to 50 or something.
Best
Sophi Kravitz wrote 02/22/2019 at 15:04 • point
Neat project. I didn't realize that Fusion had a built in gear generator. Off to try it now :)
adamc wrote 02/16/2019 at 00:42 • point
I've managed to build one and get it running, I did have a bit of trouble with the drum and peg. I redid it slightly as it was slipping a little, also had to build out the nub on the drum to press the NC stop a little more as mine wouldn't trigger. I'm also unsure where the spacer should go?  Does it go on the gear end of the drum? I noticed that the flaps would touch the microswitch on the end stop I've got in there. The other bit I'm looking at is that the flaps hit the bolt holding the motor in, so might recess that bolt a bit , although it doesnt seem to be a problem. I've also put a 2mm bolt through the middle of the drum and the drum2 disk which helps hold it together. I've got a homing routine done now and working on positioning the flaps now. It's working really good :)
(ignore the spacer question, I've just seen it on the exploded diagram)
jonas wrote 02/16/2019 at 05:48 • point
the nubs worked fine with me weird.
About the bolt hitting the flaps, I've actually just removed the bolt. It works fine without the motor sits snugly and I didn't want to move it backwards because that way the unit would be even deeper than it is now.
Great that you are thaking it further! I haven't had the time the last couple of weeks to work on it.
adamc wrote 02/18/2019 at 14:13 • point
hey, just to let you know i have it working with a Wifi Wemos as well now.  I'm using it to display recent twitter users that I follow. I'm going to post the code up on instructables most likely and checking that its fine to include the modded files I've done with links and credits back here of course
jonas wrote 02/18/2019 at 16:32 • point
As long as you attribute and link back its fine. I'm looking forward to seeing what you've done with it.
adamc wrote 02/14/2019 at 19:27 • point
great project, I'm printing one now. Was the mult-part mount and base etc. done in such a way to avoid supports with printing? I wondered if it was possible to print the main unit as one piece with supports perhaps for the arm that holds the flaps back?
I've ordered up some endstops, but also wanted to know what bearings you had used, were they 625ZZ or similar  16mm OD 5mm thick and 5mm I/D?
jonas wrote 02/14/2019 at 21:01 • point
hey thanks. Well yes I try to design in such a way as to avoid supports. You could try to do otherwise offcourse, I just try to avoid it. 625zz are the bearings I used.
octebra wrote 02/14/2019 at 02:17 • point
Great project, how do you power the stepper as a motor I am in the process of designing and building a wooden gear clock and I need a controllable motor to turn the gears.
Brian Lough wrote 02/10/2019 at 11:36 • point
I love this Jonas! I was actually looking for something like this week and couldn't find anything.
I have a question regarding keeping track of where you are, you are using the end stop to count how many flaps have gone past is it? Or is it triggered by the nub on the top of the wheel that the flaps are attached to?
jonas wrote 02/11/2019 at 06:21 • point
It is triggered by the nub, so it senses its position once per rotation.
Brian Lough wrote 02/14/2019 at 11:49 • point
I printed one of these out, I'm just waiting for the end stop and bearing to come from China (so it will be a while :)
fabian wrote 02/07/2019 at 11:25 • point
can You increase a speed?
is possible to create big number of chars?
for example 127 ascii code?
jonas wrote 02/07/2019 at 19:44 • point
the speed in the video is about half of the maximum, but I like the leisurely speed
you can definitely have split flap display that have a full range of numbers and letters but I've never heard of anything beyond that.
fabian wrote 02/07/2019 at 22:25 • point
127 chars
Jon wrote 02/13/2019 at 17:30 • point
Martin wrote 02/05/2019 at 12:19 • point
You do not even need to cut the connection to drive the motor bipolar. There should be zero net voltage at the connection between the two phases. But in this low power application I would not bother about bipolar drive or is it THAT weak?
jonas wrote 02/05/2019 at 19:16 • point
Really? I figured there would some interference. I'll definitely test it out thanks for the tip
Martin wrote 02/07/2019 at 09:32 • point
Of course it depends on the symmetry of the windings. But you can easily test this by measuring the resistance (and if possible the inductance values) of the half windings.
andres ortiz wrote 02/04/2019 at 22:39 • point
well done, I love it!
Dan Maloney wrote 02/04/2019 at 15:59 • point
Hey, that's awesome! Do you think the flaps are thick enough to take debossed characters? Or are you planning to just add labels to create the characters?
jonas wrote 02/04/2019 at 20:10 • point
the idea is to create the characters using different colors over multiple layers. the flaps are 1mm think so I hope thats enough. If it isn't, well labels are an alternative as you said.
