Before you kill your RPi...
06/02/2020 at 15:33 • 0 commentsI have twice now killed a GPIO input pin by forgetting that 5V is greater than 3V3. This is annoying, but at least it's not the whole Pi. I updated the schematic to include the simple potential divider that I keep forgetting (circled in red). The values aren't too critical, here I've selected them to keep the output (input into the Pi) below 3V even if the input gets to 5.1V.
Configuring a RPi for mUPS
05/27/2020 at 21:32 • 0 commentsThis is what I did, based on my experience (not a lot) and research (not enough?). There may be better ways to do it. Feel free to tell me what I'm doing wrong in the comments ;-)
Basics:
- Using Ubuntu MATE 18.04 for RPi, downloaded 22 May 2020 (lost password and hadn't done anything with previous ROS install so didn't mind starting over).
- 16GB Sandisk µSD
- Wired Ethernet connection (already setup). Otherwise, pre-configure WiFi with wpa_supplicant.conf
- KVM switch for easy use of GUI.
Install OS
- Unzip (7-zip)
- Flash .img to SD (balenaEtcher)
- Insert & power-on
Check, set and update via config tool
Boot to GUI or CLI etc…
sudo raspi-config
May as well update everything…
sudo apt-get update && sudo apt-get upgrade
Not necessary, but useful
Edit /boot/config.txt and add/change both of these...
dtparam=pwr_led_trigger=heartbeat #nice load indicator dtparam=watchdog=on
Create/copy-in the mUPS.py file
(filenames are case-sensitive!)
######################################################################################### # mUPS.py handles UPS/main-power switch-over and RPi shutdown for Droidbot. # P.Crouch # Rev3 # May 2020 # # *** Developed for my own use and provided as-is, with no guarantees *** # # RPi signals to mUPS when it is up. mUPS tells Pi to shutdown and waits for RPi_UP # to go low before removing power. ######################################################################################### RPi_UP=21 # pin 40 RPi_SD=27 # pin 11---------- more ----------import RPi.GPIO as GPIO GPIO.setmode(GPIO.BCM) import time import sys from subprocess import call GPIO.setup(RPi_UP, GPIO.OUT) GPIO.setup(RPi_SD, GPIO.IN, pull_up_down=GPIO.PUD_DOWN) # active-high from UPS (RPi_SD) ######################################################################################### try: GPIO.output(RPi_UP, GPIO.HIGH) # signal when PI is up while 1: if GPIO.input(RPi_SD): call(['shutdown', '-h', 'now'], shell=False) time.sleep(5) # sleep to reduce unnecessary CPU usage ######################################################################################### finally: GPIO.cleanup()Create Bash script
Create new text file called mUPS.sh with the following contents:
#!/bin/sh cd /home/yourusername/ sudo python mUPS.pyIIRC it wouldn't run before login (no good if running headless and not logging-in during normal operation), so python code needed to run with sudo.
Make both files executable (for all users)…
chmod u+x mPSU.pychmod u+x mPSU.shTest it:
./mUPS.sh
RPi_UP (pin 21) should go high.
Create Cron job to run script at startup
(on newer distros without the rc.local that I used before - workarounds didn't work for me)
Create a cron job that will wait 10 seconds after system startup, then execute the specified script. Sudo is required again here, else you'll edit the user crontab.
sudo crontab -e…enter the following:
@reboot (sleep 10; sh /home/yourusername/mUPS.sh)A reboot is considered to be the point at which the daemon starts, it may be before other system daemons so use/test a suitable sleep period.
sudo crontab -lTo confirm that the cron job has been inserted.
Reboot to test it.
At this point the mUPS works almost flawlessly. Almost. I noticed some relay chatter at Arduino power-on that I need to investigate...
Testing new code
05/22/2020 at 16:07 • 0 commentsI've reworked things as the Coronavirus chaos has given me some time to revisit the design.
I've just fixed some issues in the new code and tested it again and it seems to work with no odd behaviour! That's a start.
Next, connect supercaps and relay...
Simply a dead battery, sort of
04/16/2019 at 21:03 • 0 commentsI pulled the UPS out again last night l so I could get at things to investigate the problem. Here’s what I found:
- The battery voltage dropped to ~2.5V after the Pi started booting.
- It behaved the same when the Pi was powered directly from the 18650 boost circuit (with the rest of the circuit disconnected).
- Another 18650 cell was swapped in and the Pi booted fine and ran until I shut it down manually.
- With the new cell in place and the rest of the circuit connected it all functioned as expected.
So I've concluded that the cell had become discharged, as it is permanently powering the boost circuit, and wasn't able to support the Pi's power requirements for boot up. I knew that the on-off switch only disconnects the output to the USB socket, but underestimated the boost circuits drain and the impact it would have when used in this manner. Compounding the problem is the DC-DC converter supplying the Pi and the cell; it can't deliver enough current to both charge the depleted cell and allow the Pi to boot.
After my last post, I had a brief discussion with Bud Bennett and I began to re-evaluate my approach. I don't actually need the option of a keep-alive mode where I can choose to keep the Pi running for minutes/hours after main power loss instead of shutting down straight away. I added it because I could. So I don't need the selectable delay provided by the µC or the indicator LEDs, again, only included because I could. The Pi is quite capable of shutting down based on the state of a GPIO pin driven from a simple divider hanging off the main supply, I just had the µC do it for flexibility. I only have to provide enough power for ~30sec. So have I over complicated it? I do that sometimes.
I could use a beefier converter capable of providing more current and ensure the cell is also disconnected from the circuit at switch off, but that's a PITA. I want to keep it simple and low cost so it'd be easy to make another for any Pi project. I'm avoiding doing a custom PCB as I'd like to stick to off-the-shelf parts so it's quick and easy to duplicate. If you need me, I've gone back to the drawing board.
Hold fire!
04/14/2019 at 13:02 • 0 commentsDammit! I went to use the Pi and the bloody thing wouldn't power up properly. The power LED lights and the activity LED briefly flickers. A USB meter showed the Pi supply voltage drops to ~3.6V after a short time. Not enough for the Pi to boot.
Maybe I've messed up the wiring and I've got some current going somewhere it shouldn't and something is overheating? I need to pull it apart again to investigate.
Version 1, kinda.
04/11/2019 at 18:17 • 0 commentsI'm calling it version 1 with the intention of revisiting it to address some lose ends and make some improvements. Version 2 will come when I need a longer hold-up, rather than the (almost) immediate shutdown.
You can find my excuses elsewhere as to why it's taken so long and why this documentation is a bit thin, but here's the short version of events:
- I needed a UPS for the Raspberry Pi to handle sudden power loss and prevent file corruption.
- The "Wemo 18650 Battery Shield" will output whilst taking power and it's cheap. I like cheap.
- The RPi can't be trusted to shut it's own power off so I looked for the smallest, cheapest Arduino-type board (to minimise faffing) to handle the delay-if-then logic. I got a couple of DigiSpark boards (clones as it turned out) and cobbled together the code and connections.
- Saw some odd behaviour, maybe the DigiSpark board isn't what I need.
- Worked around the issue, circuit and code seem to work on the bench until the RPi is actually connected (instead of manually simulating the I/O signals).
- (some time later) Sick of the DigiSpark; I switch to the trusty Nano, then add some traffic-light LEDs for indication and because I can.
- More odd behaviour; looks like back-feeding through the µC inputs. I should really disconnect the GND too.
- I transplant a small DPDT relay onto the opto-isolated "arduino" relay board and re-wire again to also break the GND this time.
Twenty-third-time lucky? - Dammit! Killed a Pi pin by forgetting 5V > 3V3. Moved to next GPIO and added a pot.div.
- Success!?! Tested the UPS with the RPi two or three times, mounted both in the head and moved on to power distribution but I'm waiting on some parts that got delayed in transit, so I'm using the time to write this. Below is the schematic I did a few days(?) ago.
UPS diagram (not showing GPIO potential divider!) Arduino
3 - RPi_UP (DI), RPi GPIO output - high after boot, low just before complete shutdown.
2 - RPi_SD (DO), RPi GPIO input - active-high to trigger shutdown of RPi (through pot.div; 5V >> 3V3).
Not Used: A0 - ADC to 18650 battery, 4V - disconnect load from battery when voltage drops.
4 - Main Power present/not present (DI).
Not Used: 5 - Keep alive/immediate select switch (DI)*
6 - Relay (DO) - active-high opto-isolated (N.O. contacts). Opens to disconnect battery.
7 - Amber UP LED.
8 - Red SD LED.
9 - Green MPP LED.
*Mode selection input:
Not Used: Keep alive = 0V - waits until battery is low before shutting down and disconnecting.
Keep alive = N.C. - immediate safe shutdown and disconnect.
Raspberry Pi
RPi signals to UPS when it is up. UPS tells Pi to shutdown and waits for RPi_UP to go low before removing power.
RPi_UP=21 # GPIO output - high after boot, goes low a few seconds before complete shutdown. RPi_SD=17 # GPIO input - active-high to trigger shutdown of RPi (through pot.div; 5V >> 3V3).
