1Step by Step
- Carefully open up the spinner case
- Cut the speaker cables close to the speaker side
- Soldering the coil in the speaker position so it could be completely cover with the spinner case
- Generate the mag-stripe data with ViolentMag library
- Connect to the Bluetooth spinner and approach the spinner to the card reader
- Play the audio & enjoy
Salvador Mendoza
