RTPD1 Built instructions.pdf
Adobe Portable Document Format - 799.84 kB - 09/30/2019 at 19:44
Preview
RTPD1-SW_v3.hex
Software for the Soldering Pen
hex - 34.13 kB - 09/30/2019 at 09:56
Download
Config file for STUSB4500 V0.2.txt
plain - 245.00 bytes - 09/30/2019 at 09:49
Download
Development and Prototype history.pdf
This document shows every prototype stage in the past with its requirements.
Adobe Portable Document Format - 1.17 MB - 09/30/2019 at 08:35
Preview
Portable Network Graphics (PNG) - 17.71 kB - 09/30/2019 at 08:28
Preview
RTPD1_v7_Mainbody and Cap.stl
3D-File of the Mainbody and Cap. Optimized for powder printing technology.
Standard Tesselated Geometry - 997.05 kB - 09/20/2019 at 17:53
Download
RTPD1 Partlist.pdf
The approximate cost calculations are without assembly fees.
Adobe Portable Document Format - 415.26 kB - 09/20/2019 at 17:30
Preview
RTPD1 Shematic.pdf
Adobe Portable Document Format - 65.33 kB - 09/20/2019 at 17:30
Preview
RTPD1 Gerber.zip
PCB should be made of 1mm FR-4 with an lead free HAL finish.
x-zip-compressed - 28.79 kB - 09/20/2019 at 17:30
Download
RTPD1-PCB-Bottom Assembly.pdf
Adobe Portable Document Format - 4.85 kB - 09/20/2019 at 17:30
Preview
RTPD1-PCB-Top Assembly.pdf
Adobe Portable Document Format - 5.25 kB - 09/20/2019 at 17:30
Preview
USB-C-PD Power supply DA45C Datasheet.pdf
Datasheet of the USB-C power supply. The price-performance ratio is good. Costs around 18€ per piece. Also good worldwide availability for example at Digikey: https://www.digikey.ch/short/pfpdrt
Adobe Portable Document Format - 438.00 kB - 09/13/2019 at 10:16
Preview
USB-C-PD Power bank RP-PB159 Website.pdf
Website snapshot of the used Power bank. Not that cheep, but can used to charge Smartphones and Tablets as well.
Adobe Portable Document Format - 567.44 kB - 09/13/2019 at 10:27
Preview
