A funny project developed by low cost IOT platform
Prepare
D-duino x1
18650 shield x1
Soil moisture sensor x1
Connect and have test like this.
Connect moisture sensor's Vcc to D-duino 3V3 pin.
Connect moisture sensor's GND to D-duino GND pin.
Connect moisture sensor's data pin to D-duino A0 pin.
First let's test sensor status in water.
There is a big different, is it?
Please follow this github project :Moisture
There are many projects about D-duino on this github.
Please go to ThingSpeak and build a new channel with 1 chart.Remember your API key and copy it to the code.
After changing WiFi ssid and password and API key you can upload code into D-duino.
Wait several seconds you will find the data displayed on the oled.
Here I set it upload to ThingSpeak every 60 seconds. It may only last for several hours.
You can expand time by fix codes.
Not only moisture sensor but also other sensor is OK!
View all instructions
Konstantin
akarshagarwal98
Christian MARTINEZ
r
Yes, delete it Cancel
You are about to report the project "Display Soil Moisture and Upload to ThingSpeak", please tell us the reason.
