TEASER
04/16/2019 at 01:55 • 0 commentsSome Teaser image of my next MINHF4 Board :))
Alpha Version of Arduino Board Manager for MINHF4 is here!!
02/15/2019 at 02:55 • 0 commentsI am releasing the Board Manager for MINHF4. There are 2 choices, but before going both ways, you have to install STM32 Cores from ST first by using this JSON Link and put it into Preferences menu:
https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json
Then, you can install MINHF4 board by these 2 ways:
The first one is to put this JSON Link into your Preferences in Arduino and it should be in the Board Manager of Arduino IDE:
https://raw.githubusercontent.com/minh7a6/MINHF4/master/Releases/package_minhf4_index.json
The second way is to install manually by downloading my MinhF4 Github and copy "MinhF4" folder inside "Release" folder into Hardware folder in Arduino.
Anyways, Happy Valentine!!
Tinkering with MicroPython on MINHF4
02/12/2019 at 18:03 • 0 commentsI've just crudely made port a version of MicroPython from the Nucleo F411RE to MINHF4 yesterday evening. Even though it is not perfectly done with pin declaring, it is a proof of concept that this board can run MicroPython.
