While working on the next pcb version one task was to improve the support for analog sine/cosine encoders.
With sincos encoders we have the option to use high resolution absolute encoders and in the next version hopefully even with differential inputs for less noise.
For testing i made a few AS5115 based magnetic encoders and mounted a magnet to the shaft of a drone motor as a test setup.
That gave me the idea to make a tiny ffb wheel :)
Could you show how you attached the magnet to the motor shaft?
hi, so how is the project going? its everything ok or you're found some problems on the way?
