Hackaday.io Hackaday.io
Sign up Log in
AirQualitySensor
Monitoring indoor air quality and visualize it with colors
xo-ne-unXo Ne Un
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
304
0
1
1
Team (1)
  • xo-ne-unXo Ne Un
Join this project's team
hardware
ongoing project
arduino LEDPixel BME680 air quality monitor
This project was created on 02/16/2019 and last updated 8 years ago.
Description
In a box where I collet leftovers from other projects I found four LED Pixels and I thought about what I can do with it. Then I remembered that I always wanted to test the sensor BME680 of Bosch (https://github.com/watterott/BME680-Breakout). This 3mmx3mm small MEMS sensor measures Air Quality, Humidity, Pressure and Temperature.
Components
  • 4 × LEDPixel https://shop.led-studien.de/de/pixel-digital-dmx/pixel-ketten/rgb-pixel-50x50mm-inkl.-wannen-kabel
Project Logs
Collapse
  • Continue with front tiles
    Xo Ne Un • 02/19/2019 at 18:46 • 0 comments
    After a month-long break, other projects got a higher priority, I continued with this project and printed to front tiles.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Made a small handy air quality meter based around the MQ135 Air Quality sensor.
Project Owner Contributor
Portable Air Quality Meter
arnov-sharmaArnov Sharma
The 2015 Hackaday Prize
An incoming mail alert system, solar powered and transmitting mail arrival notifications wirelessly to an "inside home" micro base station.
Mbas - Mail box alert system
clovis-fritzenClovis Fritzen
In this project “DIY Air Quality Tester” we use Node MCU microcontroller and air quality sensors to measure various gases concentration.
electronicsworkshopselectronicsworkshops
Checking out how carbon monoxide detectors work in a controlled environment
Testing Carbon Monoxide Detectors
adam-fabioAdam Fabio
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "AirQualitySensor", please tell us the reason.
Send message
Remove Member
