Hackaday.io Hackaday.io
Sign up Log in
AirQualitySensor
Monitoring indoor air quality and visualize it with colors
xo-ne-unXo Ne Un
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
304
0
1
1
Team (1)
  • xo-ne-unXo Ne Un
Join this project's team
hardware
ongoing project
arduino LEDPixel BME680 air quality monitor
This project was created on 02/16/2019 and last updated 8 years ago.
Description
In a box where I collet leftovers from other projects I found four LED Pixels and I thought about what I can do with it. Then I remembered that I always wanted to test the sensor BME680 of Bosch (https://github.com/watterott/BME680-Breakout). This 3mmx3mm small MEMS sensor measures Air Quality, Humidity, Pressure and Temperature.
Components
  • 4 × LEDPixel https://shop.led-studien.de/de/pixel-digital-dmx/pixel-ketten/rgb-pixel-50x50mm-inkl.-wannen-kabel
Project Logs
Collapse
  • Continue with front tiles
    Xo Ne Un • 02/19/2019 at 18:46 • 0 comments
    After a month-long break, other projects got a higher priority, I continued with this project and printed to front tiles.
View project log
Log In/Sign up to comment
Sign up with Github
OR
An open project to improve the IKEA VINDRIKTNING air quality sensor
Project Owner Contributor
IKEA VINDRIKTNING ZIGBEE
andrew-lamchenkoAndrew Lamchenko
The 2015 Hackaday Prize
An incoming mail alert system, solar powered and transmitting mail arrival notifications wirelessly to an "inside home" micro base station.
Mbas - Mail box alert system
clovis-fritzenClovis Fritzen
I built a gesture sensor that works through solid objects—no exposed optics needed. Huge upgrade for my project!
I Built a Gesture Sensor That Works Through Object
realcorebbRealCorebb
Checking out how carbon monoxide detectors work in a controlled environment
Testing Carbon Monoxide Detectors
adam-fabioAdam Fabio
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "AirQualitySensor", please tell us the reason.
Send message
Remove Member
