Hackaday.io Hackaday.io
Sign up Log in
ATtiny13 - PI metal detector
This experimental project shows how to build an AVR microcontroller based simple PI (Pulse Induction) metal detector.
ukasz-podkalickiŁukasz Podkalicki
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.2k views
1 comments
12 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
2.2k
1
12
8
Team (1)
  • ukasz-podkalickiŁukasz Podkalicki
Join this project's team
  • Project Homepage
  • Source code
completed project
hardware
pi Metal detector avr attiny13 attiny
This project was created on 02/18/2019 and last updated 7 years ago.
Description
My goals were to make a circuit as simple as possible and to use only popular / cheap electronic parts. The device has been tested with very small coil (55mm diameter, about 30 turns of 0.5 DNE) and only 3.0V power supply. It’s my first design of PI metal detector and I’m really happy with the results! The prototype was able to detect little coins (6cm distance) and wires in the wall.
Presented metal detector uses PI method to generate a voltage spike in a search coil connected in parallel with capacitor. Next, ATtiny13 uses an Analog Comparator to measure a decay time to zero of resonant circuit. When a metal object nears the loop it will decrease time it takes for the pulse to decay to zero. The change in the width of resonance time is measured to signal the presents of a metal target.
Details
Log In/Sign up to comment
Sign up with Github
OR
powiadam.ci wrote 06/19/2022 at 17:25 • point
Idz na całość i zrób taki do wykrywania w ziemi. Wystarczy 50cm. Ale dobrze by było jednak podłączyc do maliny czy innego komputera i użyc sieci neuronowych
An affordable oscilloscope for anyone who enjoys soldering their own projects.
Project Owner Contributor
Oscilloscope From Pi Pico and Android Phone
doctor-voltDoctor Volt
WIZnet W5500 + RaspberryPI5 PoE+
Raspberry Pi 5 + PoE
alanAlan
If you want accurate time stamps for your application when your Raspberry Pi boots without being connected to the network, you need a RTC.
Raspberry Pi : DS3231 Real Time Clock
alfredcAlfredC
Raspberry pi powered fox hunt transmitter
PiFox
km4efpKM4EFP
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny13 - PI metal detector", please tell us the reason.
Send message
Remove Member
