HACKDAY_FINAL.PCBPCB file, for Protel Client PCB editorpcb - 502.74 kB - 12/07/2016 at 13:21 |
HACKADAY_P3.zipGerbers for PCBs. Five badges on a single panel.x-zip-compressed - 178.03 kB - 12/07/2016 at 13:17 |
ChallengeB.HEXThe same challenge firmware, modified for the first version of the badge, used at Belgrade conferrence, April 9th 2016.hex - 16.20 kB - 12/06/2016 at 20:53 |
Challenge.HEXSolve the puzzle and win a prize!Good luck! hex - 16.56 kB - 11/05/2016 at 17:10 |
Badge Manual V1R0.pdfSame manual, if you prefere PDF formatAdobe Portable Document Format - 1.39 MB - 11/05/2016 at 04:35 |
Badge Manual V1R0.docxA brief manual for badge hackingdocument - 1.78 MB - 11/05/2016 at 04:27 |
demo 2.HEXFile ready to be bootloaded by Hackaday Superconference Badge. It is very similar to the file DEMO 2.HEX from the .ZIP file, only a few timing constants were modified.- 19.35 kB - 11/05/2016 at 18:57 |
kernel 2.hexFirmware for Hackaday Superconference Badge, ready for MCU programming. Contains Bootloader (0x0000 - 0x2AFF) and Kernel (0x2B00 - 0x32FF). This file is the same as in the .ZIP file, available here for convenience.hex - 35.46 kB - 11/03/2016 at 04:12 |
Kernel 2.zipSource files for Superconf II badge.Kernel 2.asm also contains bootloader 2.inc, which is actually the bootloader binary file, organized as data table. Demo 2.hex should be bootloaded via USB. Everything (except the bootloader) is written in assembly language. Detailed description will be available soon. x-zip-compressed - 368.33 kB - 10/22/2016 at 20:17 |
Voja Antonic
