A poor's man lathe
03/05/2019 at 07:26 • 0 commentsTurns out the wall of the casing is a tad too thick in order to fit the neopixel ring I just received.
And I don't have access to a lathe, so I shaved off the 1mm excess with a coarse round file after mounting the casing on a drill. I clamped the portable drill on the bench for that and such filed the inside for 30-40mm.
I then finished the surface with sandpaper.
First test
02/28/2019 at 07:58 • 0 commentsI put together the components without the casing and wrote some code for testing. Here's a short video that shows how it works with the volume
vincentmakes
