1Watch
1: watch jairus of all construction videos
2Understand
2: understand how it all works
3Draw
3: draw the different aluminum party
4Cut
4: cut out the ones you drew
and try to make the system in (EVA) mousse for example -
5creates the plan with exact measurements
5: if your system works well you can pass a draw the true measure
6cut into the aluminum plate
6 : then cut out your pieces in an aluminum plate 1 mm / 1.5 mm thick
7Assembly
then assemble the different piece cutting in the aluminum with the help of the video of jairus of all (Iron Man Rocket Launcher Build Part 5)
