1Get this PCB manufactured!
LoRa-gateway-single-channel-PCB
FRONT SIDE IMAGE OF THE PCB
This PCB is a sinle channel gateway of LoRa, You can use this PCB as a node as well. The Pcb uses:
- ESP8266 as the microcontroller
- Ra-02 LoRa module.
- OLED SSD13086 0.96' display
- Other basic components.
There is also an easy to program header under the OLED display to flash the device by connecting FTDI chip.
ORDERING THE PCB
I would also recommend to get your PCB manufactured at least 2 pieces. You can order your PCBs from PCBWAY as they offer 10 PCBs for just 5$. Check out their online Gerber viewer function.
BACK SIDE IMAGE OF THE PCB
This is the schematic for the project:
