While waiting for the prototype board, it became clear that some small changes are desirable for much easier programming. Today the board came in and it's already obsoleted. To test our ideas, we add two patch wires and change the resistors from pull-up to pull-down. The pins for banking will also change, but I didn't bother to patch those as I put in the original 32K chip anyway. Nothing is socketed, so it fits inside the existing enclosure. Will it work?
Marcel van Kervinck
