Functional atom punkish stun gun
MPEG-4 Video - 5.23 MB - 03/02/2019 at 19:09
View all 9 components
your accent sounds like a mongoloid vehemently slapping mayo on a wall.
so what you are really saying is that you enjoy anal?
this was what i used, I doubt it actually puts out what they claim, but you can get a solid 2" arc from it. https://www.amazon.com/3V-6V-400000V-Module-Voltage-Generator/dp/B07KNVG8Z4/ref=sr_1_16?crid=36K7XF3WQWD5G&keywords=dc+3v-6v+bis+400kv+400000v+boost+step+up+power+module+high+voltage&qid=1551793817&s=gateway&sprefix=400kv+boost%2Caps%2C140&sr=8-16
They let people in with broad swords and axes... But no, i just used the boost converter for the high voltage.
Jeez, can't imagine why they wouldn't let you in with that...
So did you use the original transformer from the Weller gun? Or just the boost converter?
Martijn
Austin Burnett
Pac
hello42world
Yes, delete it Cancel
You are about to report the project " Atom punk prop gun", please tell us the reason.
