^5 Test Mode Self-Test Style From RPUno
07/11/2019 at 18:38 • 0 commentsIf the RPUpi were to be integrated onto an RPUno, I would want it tested with a self-test.
https://github.com/epccs/RPUno/tree/master/XcvrTest
That was a lot of effort; the good news is that it should mostly copy to my other boards which I plan to gradually integrate this into (and then ditch all sorts of headers). The 40 pin R-Pi interface will be my path forward, I have grown comfortable with what the R-Pi foundation is doing.
picocom -b 38400 /dev/ttyUSB0 picocom v2.2 ... Terminal ready RPUpi Transceiver Test date: Jul 11 2019 avr-gcc --version: 5.4.0 I2C provided address 0x31 from manager SMBUS cmd 0 provided address 49 from manager MISO loopback to MOSI == HIGH MISO loopback to MOSI == LOW SCK with Shutdown loopback == HIGH I2C Shutdown cmd is clean {5, 1} SCK with Shutdown loopback == LOW I2C Shutdown Detect cmd is clean {4, 1} Testmode: default trancever control bits I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: read Xcvr cntl bits {50, 0xE2} PWR_I /w no load using INTERNAL_1V1: 0.024 A Testmode: nCTS loopback to nRTS I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xA2} Testmode: read Xcvr cntl bits {50, 0x22} Testmode: Enable TX pair driver I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xF2} Testmode: read Xcvr cntl bits {50, 0xF2} PWR_I /w TX pair load: 0.044 A Testmode: Enable TX & RX(loopback) pair drivers I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xD1} Testmode: read Xcvr cntl bits {50, 0xD1} PWR_I /w TX and RX pairs loaded: 0.066 A RX loopback checked Testmode: Enable DTR pair driver I2C Start Test Mode cmd was clean {48, 1} I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5} Testmode: set Xcvr cntl bits {51, 0xE6} Testmode: read Xcvr cntl bits {50, 0xE6} PWR_I /w DTR pair load: 0.044 A [PASS]
^5 SMBus with the R-Pi
06/17/2019 at 18:20 • 0 commentsFirst: on ^4 I should have connected the SPI nSS to R-Pi's CE00 pin (oops).
I have been working on the Remote FW for this board, splitting the hulk into smaller parts so they can fit in my brain. Also adding I2C commands that control the bus manager, and trying out the SMBus interface... and then it happened. I did not have a clue what was going on, and it has taken far to long to understand. In short, the R-Pi zero has a problem with clock-stretching.http://www.advamation.com/knowhow/raspberrypi/rpi-i2c-bug.html
After finally understanding the problem and getting past the sinking feeling, I had an idea.
Interleaving between two buffers (A and B) within the twi ISR used by SMBus interface. And without much testing yet, it seems to have done the trick.
The buffer used by the ISR is swapped after passing it to the user (e.g., with receive callback function). The user receive function runs within the ISR context, but now it can be concise (e.g., save the pointer and byte count). Then all the work can be done outside of ISR context since the buffer is no longer in the risk of being changed, at least until a subsequent receive event when it will be swapped back into service.
The quick receive event seems to be tolerated by the R-Pi's clock, but more testing is needed. The handle_smbus function is run in the main loop if there are SMBus bytes available.
^4 updates
09/22/2018 at 21:38 • 0 commentsThis update really only needed the SPI nSS connected to the Raspberry Pi's CE10 pin. The change of the transceiver was not really important, other than showing a different one that should work (if it works it cost less, but that is likely bait). Removed stuff (terminations, manager ADC6, and ADC7) for simplification. Routed I2C1 to the R-Pi SMBus so only populate this board with a ATmega328pb which was proven with RPUadpt^6 (a 328p will damage the R-Pi SMBus pins).
What do you think about the slogan? I think "Intelligence at the network edge" was Intel's but my interest is more in having the tool-chain at the edge. It means I can bootload directly (not through an adversary) and no network stack so simpler microcontrollers are viable.
^3 SPI Interface
08/24/2017 at 06:16 • 0 commentsFirmware SpiSlv is used to enable the SPI port on a RPUno (ATmega328p).
After loading the firmware on an RPUno and enabling the AVR's SPI I next need the Raspberry Pi SPI hardware setup. Raspian needs its interface master driver enabled (e.g. raspi-config).
Raspibin has an spi group setup in /etc/udev/rules.d/99-com.rules. So I can add my user name to that group for the system to allow me to use the interface.
sudo usermod -a -G spi rsutherland # logout for the change to take
Next I compile and run spidev_test.c on the Pi with:
wget https://raw.githubusercontent.com/raspberrypi/linux/rpi-3.10.y/Documentation/spi/spidev_test.c gcc -o spidev_test spidev_test.c # run with ./spidev_test -s 100000 -D /dev/spidev0.0 ./spidev_test -s 500000 -D /dev/spidev0.0 ./spidev_test -s 1000000 -D /dev/spidev0.0 ./spidev_test -s 2000000 -D /dev/spidev0.0 spi mode: 0 bits per word: 8 max speed: 500000 Hz (500 KHz) 0D FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DE AD BE EF BA AD F0
Note: The output is offset a byte since it was sent back from the AVR. I see errors at 1MHz and 2MHz. The RPUpi^3 has a 74LVC07 buffer that pulls down through a 10kOhm resistor on SCK and MOSI. The circuit between that resistor and the AVR has some capacitance which will limit the speed (if there is a need for higher speed it may be possible to swap in a 1k resistor).
^3 Bootload Remote AVR
08/24/2017 at 06:12 • 0 commentsThe hostname of the Pi Zero is pi3, it was the third Pi Zero I have setup (it is a bad hostname). The default bootload address on the RPUftdi (e.g. my multi-drop RS-422 board) is '0', and I have not changed it, I keep the i2c-debug firmware on an ATmega328p board under the RPUftdi for use on my test bench, so I will just upload that same program compiled from the Pi Zero.
rsutherland@pi3:~/Samba/RPUno/i2c-debug $ uname -a Linux pi3 4.9.41+ #1023 Tue Aug 8 15:47:12 BST 2017 armv6l GNU/Linux rsutherland@pi3:~/Samba/RPUno/i2c-debug $ make bootload avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o main.o main.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o i2c-scan.o i2c-scan.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o i2c-cmd.o i2c-cmd.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o ../Uart/id.o ../Uart/id.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o ../lib/timers.o ../lib/timers.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o ../lib/uart.o ../lib/uart.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o ../lib/twi.o ../lib/twi.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o ../lib/rpu_mgr.o ../lib/rpu_mgr.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o ../lib/adc.o ../lib/adc.c avr-gcc -Os -g -std=gnu99 -Wall -ffunction-sections -fdata-sections -DF_CPU=16000000UL -DBAUD=38400UL -I. -mmcu=atmega328p -c -o ../lib/parse.o ../lib/parse.c avr-gcc -Wl,-Map,I2c-debug.map -Wl,--gc-sections -mmcu=atmega328p main.o i2c-scan.o i2c-cmd.o ../Uart/id.o ../lib/timers.o ../lib/uart.o ../lib/twi.o ../lib/rpu_mgr.o ../lib/adc.o ../lib/parse.o -o I2c-debug.elf avr-size -C --mcu=atmega328p I2c-debug.elf AVR Memory Usage ---------------- Device: atmega328p Program: 8684 bytes (26.5% Full) (.text + .data + .bootloader) Data: 375 bytes (18.3% Full) (.data + .bss + .noinit) rm -f I2c-debug.o main.o i2c-scan.o i2c-cmd.o ../Uart/id.o ../lib/timers.o ../lib/uart.o ../lib/twi.o ../lib/rpu_mgr.o ../lib/adc.o ../lib/parse.o avr-objcopy -j .text -j .data -O ihex I2c-debug.elf I2c-debug.hex rm -f I2c-debug.elf avrdude -v -p atmega328p -c arduino -P /dev/ttyAMA0 -b 115200 -U flash:w:I2c-debug.hex avrdude: Version 6.1, compiled on Jul 7 2015 at 10:29:47 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch System wide configuration file is "/etc/avrdude.conf" User configuration file is "/home/rsutherland/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : /dev/ttyAMA0 Using Programmer : arduino Overriding Baud Rate : 115200 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : Arduino Description : Arduino Hardware Version: 3 Firmware Version: 4.4 Vtarget : 0.3 V Varef : 0.3 V Oscillator : 28.800 kHz SCK period : 3.3 us avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e950f avrdude: safemode: lfuse reads as 0 avrdude: safemode: hfuse reads as 0 avrdude: safemode: efuse reads as 0 avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "I2c-debug.hex" avrdude: input file I2c-debug.hex auto detected as Intel Hex avrdude: writing flash (8684 bytes): Writing | ################################################## | 100% 1.20s avrdude: 8684 bytes of flash written avrdude: verifying flash memory against I2c-debug.hex: avrdude: load data flash data from input file I2c-debug.hex: avrdude: input file I2c-debug.hex auto detected as Intel Hex avrdude: input file I2c-debug.hex contains 8684 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 0.95s avrdude: verifying ... avrdude: 8684 bytes of flash verified avrdude: safemode: lfuse reads as 0 avrdude: safemode: hfuse reads as 0 avrdude: safemode: efuse reads as 0 avrdude: safemode: Fuses OK (E:00, H:00, L:00) avrdude done. Thank you. rsutherland@pi3:~/Samba/RPUno/i2c-debug $ picocom -b 38400 /dev/ttyAMA0 picocom v1.7 port is : /dev/ttyAMA0 flowcontrol : none baudrate is : 38400 parity is : none databits are : 8 escape is : C-a local echo is : no noinit is : no noreset is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv imap is : omap is : emap is : crcrlf,delbs, Terminal ready /0/id? {"id":{"name":"I2Cdebug^1","desc":"RPUno Board /w atmega328p and LT3652","avr-gcc":"4.8"}} /1/id? {"id":{"name":"PwrMgt","desc":"RPUno Board /w atmega328p and LT3652","avr-gcc":"4.9"}} Thanks for using picocom rsutherland@pi3:~/Samba/RPUno/i2c-debug $
So this seems to have worked. The Pi cross compiler for AVR is older than the one on Ubuntu 16.04.
^2 Board Arrived
06/04/2017 at 04:02 • 0 commentsOSHPark did a great job as always, unfortunately, I had a brain fart and forgot that the AVR microcontroller under the shield connects to the RS-422 transceiver through the 74LVC07 buffers I used. I was trying to use the buffers IOFF state to allow the Pi Zero to be powered off without pulling down the RS-422 bus.
When U3 (74LVC07) does not have power the serial RX and TX from shield can not reach the RS-422 transceivers.
For testing, I need to cut U3 power from the PI3V3 node and bridge it to the +3V3 node.
So far this hack is working, but I have another board on the way so this will soon be back on a spin loop thread.
