A self-designed UV-cure, LCD masked, 3D resin printer. Originally meant to be a single column Z-axis, I went with a dual column Z-axis design. This documents my design and build process for the printer
Components
1×
40W 405nm UV LED Module
Provides the 405nm UV light to cure the resin.
1×
LED Module Heat Sink + Fan + Light Spread Lens
Used to keep the LED module cool.
2×
8mm to 5mm aluminum coupler
4×
Linear Rail + MGN12 carriages
2 per Z axis column
