This is what the finished Rev1 looks like. There were some issues around the joystick port, and I've added a couple features for Rev2. I'm working on that now.
So the video generation is working. DVI-D through a passive HDMI converter, to an HDMI small form factor monitor. Also, the CPU is running and executing code, and I used it to configure the DVI encoder via I2C.
I'm working on building up the board. The FPGA is programming nicely, I've got the UART working, and I'm building up all the missing parts. Still waiting on a few connectors, and adding things as I test.
Had a bit of an issue sending a bitstream to the FPGA. After some bug hunting, I realized it was just an electrical noise issue. Added a bunch more decoupling capacitors and now I can program it.
I got my reflow oven working and attached my first BGA!
I didn't know how well it would work, so I only attached the 2 parts I absolutely needed reflow for. I'll hand solder things on as I need them for this board.
