Hackaday.io Hackaday.io
Sign up Log in
Color VFD Clock
Clock designed around the Noritake itron GU20X8-301 color VFD module
natalienatalie
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.5k views
9 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 9
View Gallery
1.5k
9
14
17
Team (1)
  • natalienatalie
Join this project's team
ongoing project
This project was created on 03/13/2019 and last updated 7 years ago.
Description
Placeholder project page. Currently, I am testing using an Arduino Mega board to interface with the VFD, and an ESP8266 to control it.
Project Logs
Collapse
  • See also...
    natalie • 03/17/2019 at 20:21 • 0 comments
    For an example of interfacing with this VFD, take a look at my other project: a port of Bad Apple!! to this display.
    https://hackaday.io/project/164433-bad-apple-color-vfd-ver
  • Falling seconds
    natalie • 03/13/2019 at 21:19 • 0 comments
    Here's a video showing some clock code I threw together a little while ago.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
b19eed wrote 05/20/2021 at 19:50 • point
did you do any more with this? I just purchased one off eBay, never used arduino before, but l have also ordered one of those... I have a lot of learning to do and could do with any assistance available ;)
Vincent wrote 03/16/2019 at 21:41 • point
We like VFD!
Ken Yap wrote 03/16/2019 at 01:20 • point
Nice! Always liked the glow of VFDs. Looking forward to seeing links to the driving software. Does that panel generate all the voltages required, as opposed to say this one? https://www.ebay.com/itm/128-32-VFD-Screen-Panel-SCM-Vacuum-Fluorescent-Display-Graphical-Dot-Matrix-Chip/273083073717
natalie wrote 03/17/2019 at 02:24 • point
Yes, just give it 5 volts (at several hundred mA...) and hook up the control lines - it uses an oldschool parallel bus. Not my repo but there is interface info here: https://github.com/cawapy/GU20X8/blob/master/gu20x8.md
Ken Yap wrote 03/17/2019 at 02:53 • point
Dan Maloney wrote 03/15/2019 at 16:21 • point
I always liked the two-color VFDs. Looks like you could make a decent game of Space Invaders on that.
namshang wrote 03/14/2019 at 18:39 • point
How much this display??
natalie wrote 03/15/2019 at 01:10 • point
stock varies, but you can pick them up for about $20 on ebay: https://www.ebay.com/itm/20x8-VFD-Screen-Panel-3-Color-Graphical-Lattice-SCM-Vacuum-Fluorescent-Display/273373691704
davedarko wrote 03/14/2019 at 08:53 • point
woah :O
Matrix style digital clock - driven from my STM32F030 VGA library
Project Owner Contributor
Matrix clock
kc-leeK.C. Lee
An esp8266 based binary city clock fork
Another City Clock
grgory-paulGrégory Paul
test project
#23 ESP8266 NTP NIXI Clock
ht3h5796-14HT3H5796-14
A Nixie clock based on V.G.C. idea and code but using a Nodemcu Lua ESP8266 and my Nixie driver board.
Yet Another ESP8266 Nixie Clock
rlb-designsrlb-designs
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Color VFD Clock", please tell us the reason.
Send message
Remove Member
