Power
03/17/2019 at 20:40 • 0 commentsWith the small LED 20x15 matrix I noticed significant power loss when using the easy connectors for the LED strips. I didn't see this problem when I soldered the LED strips, it's a pain but seems like worth the effort. I used a 5v 20amp power supply with the 20x15 matrix. With the large LED matrix each LED strip will have a 180 LEDs (8.2 ft). I am not planning on running all the LEDs while at full power. White at full power each LED draws up to 60mA. I did some testing and this seemed very accurate. I also needed to know how my power supply would handle over current conditions. I shorted out the 5v side and was happy to see that the cheap chinesse power supply had over current protection (not that I want to exercise this).
I will have a total of 150x14=2100 LEDs ( I'm using 300 LED strips).
150LEDs x .06mA = 9A again this is not a condition I will be running. But I need to know the worst case. This is also at the brightest level. I am planning on running it at 150 (highest 255) and avoiding lighting all LEDs at White.
I have decided on using two 5v 60AMP power supplies.
One area I am concerned about is the the environment that the power supplies will be running in. The barn does not have AC and gets hot and very humid in Maryland. I am planning on mounting mounting a fan to help cool the power supplies. At this point I'm leaning towards a 120v fan instead of a 5v fan, mainly because I need this system to work for year after year, and I think the 120v will be more reliable in the long term.
Take Keyboard data
03/17/2019 at 20:15 • 0 commentsI was looking for a method to enter new phrases that would be displayed. With the 20x15 display everything was hard coded, this would not work with this display. I wanted to find a way to enter new phrases with a USB keyboard. The Arduino could not work directly with the USB keyboard. I found this device and ordered one.
http://www.hobbytronics.co.uk/usb-host-board-v2?keyword=usb%20host
This would communicate I2C with the arduino and I could order it with the USB keyboard profile already loaded, less work for me to do :D This worked great, at first I was using a USB keyboard that had a USB port on it, and the device would no recognize it. I then found a simple USB keyboard (no USB host ports on it) and it worked perfectly, this was also nice an inexpensive.
hello
One important item I noted. I need to make sure I have a very strong mounting case to allow "Anyone" to connect the USB keyboard. I don't want people not familiar with the hardware to have to hold the devices to connect the USB keyboard. I need to mount this securely in a box. Now I can get input form a USB keyboard.
Features I need to add to support this.
1. I will have four "Phrases" being displayed in a rotating pattern. When I see "xxxx" I will know that new data is coming in. I will flash some LEDs, green, as a visual feed back to the operator.
2. Need to work out the buffer timing. The default "USB Host program" checks every 5 min. I need to create a buffer on the Arduino side, so I can handle not being spread across USB Host buffer.
3. Need visual feed back that each "phrase has been accepted".
4. Go back into display mode
