Hackaday.io Hackaday.io
Sign up Log in
Servo Controlled Word Clock
This variation of the popular word clock is controlled by 114 servo motors.
moritz-v-siversMoritz v. Sivers
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
7.1k views
13 comments
315 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 13
View Gallery
7.1k
13
315
76
Team (1)
  • moritz-v-siversMoritz v. Sivers
Join this project's team
MISC
completed project
word clock servo
Related lists
Clocks
clock projects
This project was created on 03/29/2019 and last updated 7 years ago.
Description
We build this variation of the popular word clock where letters are projected from the back onto a screen. In addition, each letter is connected to a linear actuator that can be moved back and forth by a servo so that the projection changes size onto the screen.
Details
Log In/Sign up to comment
Sign up with Github
OR
jkqq147 wrote 07/31/2019 at 23:13 • point
NB
Steve wrote 04/16/2019 at 17:29 • point
Any detailed instructions and files available for this amazing project?
Dillon Nichols wrote 04/15/2019 at 13:16 • point
Amazing build video and even better end result. That took a lot of work and watching it display the time is phenomenal.
nerill.dp wrote 04/11/2019 at 11:59 • point
Like I mentioned on your Youtube video, wow, your ingenuity and patience are inspiring. Your build video is mesmerizing. In fact, I like the video so much, I've set it to half-speed with volume off and just let it loop on my tv as background art. Very satisfying to watch.
2019 wrote 04/10/2019 at 18:52 • point
At my place it says, the video is not available :(
Jan wrote 04/10/2019 at 18:56 • point
just use a site like https://unblockvideos.site/ in case this happens to you :)
schlion wrote 04/10/2019 at 21:26 • point
I had the same problem. You can try clicking on the video title. This will take you directly to youtube, where the video might not be blocked.
2019 wrote 04/11/2019 at 12:34 • point
Indeed! Play button still says no, while youtube says yes: https://www.youtube.com/watch?v=f-2w-D18m9c Thanks! The video alone is a masterpiece. And then there is The Clock! Glad i could see that.
Jan wrote 04/10/2019 at 17:29 • point
Let me add another "wow"! Awesome work. I first thought the illuminated backgroundtext was printed but damn, it's done by the more distant LED-bricks...
Amazing outcome!!!
DrZoid wrote 04/04/2019 at 06:47 • point
wow wow wow
danjovic wrote 04/02/2019 at 21:45 • point
I am dumbfounded by how this clock of yours can be  so simple and so complex at the same time. And how beautiful it is!!!
Dan Maloney wrote 03/29/2019 at 23:32 • point
You already got two wows, but let me add one of my own. Wow!
Love it! Only so many ways to make a word clock, and this one is really inspiring. I wrote it up for the blog, so watch out for it over the next few days. Great job!
Gerben wrote 03/29/2019 at 19:51 • point
Wow. Wow. I'm impressed. Very original, and looks great.
A special Clock witch is build with 22 Servos instead of LEDs at a 7-segment display.
Project Owner Contributor
Servo Clock
ebrithilebrithil
A clock based on magnetic field viewing film. Behind the viewing film numbers made of magnetic material are arranged on four wheels.
Magnet Viewing Clock
GloWatch is simply a clock. However it is a clock without any hands, but with many glowing lights instead. Its frame is entirely handcrafted
GloWatch
robertoRoberto
Just making simple alarm clock nothing else.
MAKING ALARM CLOCK
tinandjartinandjar
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Servo Controlled Word Clock", please tell us the reason.
Send message
Remove Member
