My main objective is to put as much functionality as possible into small device with amazing battery life.
Estimated size shouldn't be any bigger than 6x8cm and thicknes depends on how many batteries you want to put inside.
Ultimate combination of ESP8266, GPS and GSM modules.
Track your lost pet, get push notifications, check most frequently visited locations.
pet_tracker_hackaday.inoino - 12.27 kB - 10/30/2016 at 19:05 |
Current status:
I'm waiting for kynar wire to finish the 3rd prototype (and first one that will be closed in a sealing bag).
After successful tests I will start finishing up. Polishing the API and mobile apps.
iOS and Android will be supported.
Solder the electrodragon ESP8266 SMD Adapter Board R2, step up converters, and battery.
Connect rx & tx pins from GPS and GSM module to choosen pins on ESP. I recommend using 12, 13, 4 and 5 for this purpose.
Connect 16 to RST and pull up CH_P0 and 0.
Pins 14 and 15 (and one more in the future) will be used for controlling gps and gsm modules via transistors.
Edit the sketch by providing your network details, phone number, API hostname, port and customize your json as you want.
great work
