The board is assembled. No major issues. There are three minor issues that will be fixed in the next revision of the PCB.
- C17,18,19 are specified as 0805 but have a larger package size. This should be fixed on the next revision, or larger parts specified on the BOM.
- R31 Silkscreen is hidden by TP1. This should be fixed on the next revision.
- The silkscreen for R35 and R36 is swapped. This should be fixed on the next revision.
I powered the board from a 15V power supply. No issues with power were found.
I loaded Micropython on the ESP32 over the USB port. No issues were found. I successfully setup the ESP to connect to the network over wifi. I will continue development and testing.
