I want to revive and enhance AfdhalAtiffTan's active cell balancer design.
Gerber_balancer compatibel parts_20190402075002.zipGerber files for making the circuit with loose componentsx-zip-compressed - 11.77 kB - 04/02/2019 at 14:52 |
Gerber_voltreg comp bms copy_20190402075030.zipgerber file for making the circuit using: https://www.banggood.com/nl/5Pcs-Mini-DC-Adjustable-Power-Supply-Buck-Module-Step-Down-Module-p-952402.html?rmmds=myaccout-bottom-viewhistory__2&cur_warehouse=CNx-zip-compressed - 8.44 kB - 04/02/2019 at 14:52 |
For using the buck converter from banggood, remove the variable resistor and solder a wire from pin 5 (FB) to the through hole on the pcb.
