The Scope2Go is an easy oscilloscope for Makers:
• Small and light
• Synchronous 2 channel measurement
• 0-5V or +-50V or +-600mA
• Only one micro USB connection is required
• Cheap
• Developed in Germany
Today, the days are rare in which you sit comfortably in your well-equipped laboratory in the basement and work on your projects. Either the necessary money for professional equipment is missing or you simply are not often enough at home.
This problem is solved by the Scope2Go. It is created as a small portable oscilloscope with sufficient accuracy. The Scope2Go only requires the Micro USB supply it does not require an extra power supply or cable.
https://hackaday.io/project/165046-autonomous-navigation
