My schematic so far:
This schematic is way better organized, and hopefully it will still make sense to me 5 years from now. I've added a ton of features since the last board revision, namely:
- The CPU can now directly access the VRAM
- I doubled the maximum pixel clock by allowing for uPD7220's wide mode (see last log)
- Added support for double buffering
- I octupled the maximum VRAM to 512KiB from 32KiB. Now we can have larger resolutions with enough RAM left over to double-buffer
Doing all this added a TON of extra logic, so if you compare the above schematic with the schematic of the previous board, this one has at least twice the components, and is far denser.
I had to add a lot of buffers so that the VRAM bus could be shared. This concerns me because it adds a few tens of nanoseconds to certain datapaths, meanwhile I've doubled the maximum VRAM clock speed to 16Mhz. The VRAM uses 55ns alone, and that doesn't count any of the hardware for uPD7220 memory cycle detection, bus sharing logic, etc. So the next step will include checking my datapaths to make sure all the components process fast enough for my clocks.
The exact behavior of the board's logic is controlled by a special control register I added:
Anyway, this is where I'm at now. The schematic isn't quite finished, once I finish it and have the board design I'll upload the files to the project.
[edit] bonus: falstad simulation of part of the circuit responsible for loading pixel data from VRAM and clocking it out, which allows wide mode: Simulation
Dylan Brophy
