Properly Meshed Planetary Design
A project log for MPRT - Modified planetary robotics transmission
The reduction of strain-wave, but using a 'single' stage planetary gearset.
agpcooperagp.cooper • 04/16/2019 at 13:07•1 Comment
For this log I present a properly meshed planetary drive:
Notes:
Generating the gears
Initially I used Gearotic (as I have a licence) but Gearotic is tricky to use if you have not used it for a while and the exported DXFs are not great. And the gears are not one shape (each). The are short "polylines".
While this was not a problem in the past when I was using Windows because I had a macro for my CAD package that could join the polyline segments. Unfortunately the macro feature does not work under Wine (as I have migrated to Linux).
In the end I decided to write my own gear code in C and export my own DXF gears.
DXF File Format
The DXF file format is an absolute nightmare. While exporting points and segments are easy, exporting polylines (i.e. shapes) that CAD packages can read in is not.
I found some old code that I have written for polylines and thought great, lets try this.
Well yes, it imports into my CAD package but my CAD package converts the polylines to segments. Not good.
I found some more old code that I have written for lwpolylines and thought great, lets try this. Well it was unfinished, I was having problems with the "handles" and never solved it.
Then I though, perhaps the problem with polylines is my CAD package. So I installed LibreCAD and yes it imports the polylines properly.  LibreCAD does not have a macro language but as it can import polylines, segments and points it does not matter if I can created simple DXF files in C. Move over DeltaCAD, LibreCAD coming through.
Gear Code
I will upload the gear code later, it still needs a user interface. But I have uploaded the DXF file. If the gears are the wrong size you can just re-scale them.
Top Level Code for the MPRT Concept
This is for reference:
{ // Top level Gear Code
  double PA=20.0;                               // Pressure angle
  double P=0.10;                                // Diametral Pitch
  double TX=0.0;
  double CX=0.0;
  double CY=0.0;
  // First Gear Set
  makeGear(2, 18,PA,P,CX,CY,0.5);              // Sun, rotate 1/2 tooth for mesh
  CX=(60-21)/P/2;
  CY=0.0;
  makeGear(2, 21,PA,P,CX,CY,0.0);              // Planet 1
  TX=CX*cos(120*M_PI/180)-CY*sin(120*M_PI/180);
  CY=CY*cos(120*M_PI/180)+CX*sin(120*M_PI/180);
  CX=TX;
  makeGear(2, 21,PA,P,CX,CY,0.0);               // Planet 2
  CX=TX;
  makeGear(2,-60,PA,P,0.0,0.0,0.0);             // Outer ring
  // Second Gear Set
  P=P*(57-21)/(60-21);                          // Change Diametral Pitch
  CX=(57-21)/P/2;
  CY=0.0;
  makeGear(3, 21,PA,P,CX,CY,0.0);               // Planet 1
  CX=TX;
  makeGear(3, 21,PA,P,CX,CY,0.0);               // Planet 2
  CX=TX;
  makeGear(3, 21,PA,P,CX,CY,0.0);               // Planet 3
  makeGear(3,-57,PA,P,0.0,0.0,0.0);             // Outer ring
"makeGear" parameters are:
Next
Now that I can design the gears for the MPRT, I  can now look at the SCARA elbow design.
AlanX
MasterOfNull wrote 04/16/2019 at 16:15 • point
Post the numbers you used, and I will port it.
