Design files ...
05/07/2019 at 13:13 • 0 commentsAll is now on github https://github.com/bobricius/uRetro enjoy ;)
Raspberry PI card :-D
05/04/2019 at 20:31 • 0 commentsIt is small joke ;) on card is also ADS1015 as ADC to read buttons ;)
Project name
04/22/2019 at 19:00 • 7 commentsHi, Any idea about cool name for this console ?????
SAMD21 card
04/12/2019 at 21:33 • 2 comments(12.8 x 30.6mm)
Dual Card ... Dual CORE :D
04/11/2019 at 20:34 • 0 commentsMain changes:
- 2X parallel micro SD slots
- 1. card MCU
- 2. card SENSOR
- you can also use 2x MCU and communicate over I2C
- no care where is MCU or sensor, they are parallel - Display is direct on board not on module
- WHY? until January I ordered on 4x on ebay by picture, I received 4x different display, with different pinout
- you can put card from top side what is more practical - I will focus to keep all compatible with display module version, which is more DIY friendly
- I think about microUSB for charging and add option for lion battery instead CR2032
This is preview for board with 2 micro SD slot.
Game card with USB
04/11/2019 at 19:37 • 2 commentsAfter thinking and hearing community voices, kill 2 wires with USB is useless.
So here is alternative with PCB USB (or metallic but this make board little longer).
This require 0.6mm board, maybe this need little sticker to 0.8mm :)
support for CPU with USB ???
04/11/2019 at 12:54 • 5 commentsI got a tip from Mr. Vlk to try Microcontrollers with native USB and read buttons via I2C.
Also Attiny85 can be reprogrammed via USB with digispark bootloader !
My fake Micro SD give me 8 wires (list only, not exact pinout):
- GND
- VCC
- SDA
- SCL
- SPEAKER
- Analog 1
- Analog 2
- Analog 3
Maybe in next version I can try this pinout:
- GND
- VCC
- SDA
- SCL
- SPEAKER
- Analog 1
- D -
- D +
With this I can expand offer of usable controllers with etc. SAMD21 or STM32
SAMD21 add now very popular Adafruit circuitpython programming feature ;)
What do you think about it?
Console in my hands
04/08/2019 at 22:48 • 5 commentsFor better dimension imagination ...
New cpu cards
04/08/2019 at 22:26 • 0 commentsAlso second envelope is full boards from OSHpark
What is new?
- CPU reversed for deeper CPU insert
- Card with Atmega328 for more hardcore games etc ARDUBOY emulation
BONUS
- Attiny85 breadboard adapter / programmer
New main board received
04/08/2019 at 22:22 • 0 commentsGood, news, I can work on upgrade.
I am just received new main boards from PCBWAY
What is new?
- Card is more inserted and not stick up
- +1 button ... 6 in total
- power buton is moved to back (needed space for button)
- all is prepared for port ARDUBOY games to Atmega328 card
