The first Board is soldered :-). On this board I did not populate the DDR2 memory or the associated power supply to reduce the total points of possible failure.
As a first test I flashed a bootloader on the SAMD10 and it worked :-). In the next days I will implement bitstream loading for the Lattice ECP5.
flow
