A nebulizer is a device for the administration of drugs in the form of a mist inhaled through the lungs. Traditionally, a nebulizer is a large, loud air pump attached to a mouthpiece. In recent years, a new form of nebulizer has come onto the market. Ultrasonic nebulizers consist of a ultrasonic piezo module (driven ~100kHz), a reservoir of liquid, and a palladium mesh screen with holes on the order of 2 micro in diameter. By driving the ultrasonic module, liquid is passed through the mesh as a fine mist.
These modules are readily available and cost about $10. For further reading, check out this publication: https://www.ncbi.nlm.nih.gov/pubmed/9552308
The application of this technology is to allow freebasing basically any drug, so long as it is soluble in water. This has many applications; ketamine has just been approved by the FDA for treatment of depression in the form of a nasal spray. This nasal spray has low bio-availabilty, because it's a nasal spray and it basically just drips right out. Nebulizing ketamine is a better way to deliver the drug, and a perfect application of ultrasonic nebulizer modules.
This project was initially to create a cheap, portable, battery-powered, and silent delivery mechanism for ketamine. To make this even more offensive, I did the industrial design based on the 'my first Sony' series of cassette recorders, boomboxes, and alarm clocks produced by Sony in the 1980s and 90s. It's a 'my first K-hole'. It's god damned hilarious and I don't care what you say.
However, because of the ability to freebase anything, this is a dangerous device. Putting nicotine (in the form of a juul refill) into the nebulizer might result in a nicotine overdose. Nicotine is an extremely powerful drug, and there is enough nicotine in a single pack of cigarettes to kill a person. The reason smoking two packs a day doesn't kill anyone immediately is because nicotine decomposes at high temperatures; smoking or vaping decomposes the nicotine, decreasing the dosage. (Chewing and snuff has a different bioavailabity).
Given that this device could deliver enough nicotine from a juul refill to the bloodstream to kill someone, I've decided to shelve this project.
Benchoff
nanoparticle
Yassin Ali Salah Ali
Chris Finn
Marios Christophorou
Stupid ethics, always ruining our hacking fun q-;
