This Adapter Works with 3.3V - 5V Logic and Power with most of the Waveshare e-ink Displays. The Resistor and Jumper Configuration for all these modules can be found printed on the back of the board.
A small Compact E-ink / E-Paper Adapter for use with a Variety of Waveshare Modules
Hello John,
I’m so pleased to have found this project, having struggled to eliminate the current draw of Waveshare’s “e-paper Driver HAT” for a battery-powered project of mine. Waveshare eventually confessed that their HAT continues to draw current even when the both the micro controller and the e-ink display are put to sleep. Not much good for a long duration battery project.
Anyway, your schematic has helped me to unravel the problem far more easily, and I have now made a version of my own - eliminating all the voltage regulator circuitry as my project is running on a stabilised 3V3.
With only the elements essential to the e-ink display, the board is just 21 x 25mm. It should suit any barebones ESP8266 or 3V3 Arduino project.
Thank you for your efforts, I’ll post any results or further thoughts here.
