Shields
05/10/2019 at 10:43 • 0 comments![]()
more samples ...
05/06/2019 at 21:44 • 0 commentsprecision is fantastic ;)
Converted to perfect cube
05/05/2019 at 21:09 • 0 commentsI replaced 10cm profiles to 20cm, now it is perfect cube and it is ready to insert top&side plates to make eye and smoke protection and connection to room outside exhaust ...
Photo mode :D
04/29/2019 at 21:52 • 0 commentssome samples ...
Latest pictures
04/27/2019 at 22:23 • 0 comments -
TEST cutting 3mm plywood and acrylic
04/27/2019 at 21:53 • 0 comments- 3,5W blue laser
- Acrylic 2 pass 10mm/min
- Plywood 2pass 200/min
Laser engraving & cutting - first run
04/25/2019 at 11:42 • 0 commentsAnother attempt, after completely ventilate the whole house from the unreal stink.
bobricius
