2nd Power Stacker Case Concept
04/26/2019 at 16:07 • 0 commentsAdded another style of a case in the details and files where the cells are separated from the PCB.
Added Which Battery to Use Section in the Details
04/25/2019 at 16:39 • 0 commentsFor all my battery projects, I tend to use the Panasonic NCR18650B but I am considering using the smaller version NCR18500.
Added Version 2 of Power Stacker
04/24/2019 at 17:02 • 0 commentsUploaded file for and early concept for Version 2 of power stacker, which uses an isolated ground and a charge controller on each lithium ion cell for connecting in series without an external cell-balancer. It may be best to first target USB powered electronics and connect cells in series then use a switching regulator to step down the voltage. Connecting in parallel and attaching a diode to each pack does reduce the voltage of the pack slightly and every volt saved counts as extra minutes of run time!
Added connector options in detail section
04/23/2019 at 07:49 • 0 comments -
Added more photos, details, files, and video.
04/16/2019 at 09:05 • 0 commentsThese are very early prototype details and of course with more resources it can be fully refined to a finished product.
