Art56GearPlate to Art56MotorCoverRing
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 11/05/2016 at 20:040 Comments
I have a hard time to understand how Art56GearPlate_01 is supposed to operate. It appears to be connected using one ball bearing, and one nut and bolt that is anchored in Art56MotorCoverRing_01 (hidden in this view).
I understand that the ball bearing is fixed to Art56GearPlate_01 but I expect that I need a second ball bearing otherwise it will rest on Art56MotorCoverRing_01 and plastic on plastic does not make a good gliding surface.
