Nexion display: Understanding the Nexion code
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 08/29/2017 at 21:072 Comments
Mystery why the Nexion Arduino code only reacted on a button release is this:
The button press is triggered by this attach-Push command.
    MotorEnable_Z.attachPush(MotorEnable_Callback, &MotorEnable_Z);
The button release  is triggered by this attach-Pop command.
     MotorEnable_Z.attachPop(MotorEnable_Callback, &MotorEnable_Z);
I took some example code from Nexion and apparently used the Pop (=release button) only
I mistakenly confused it with a LIFO buffer.  Push-Pop
Analyzing the Nexion protocol I also discover that it is not wise to use big names as buttons at the HMI implementation. When you request data from the HMI then it sends a big command to the Nexion slowing down the serial communication.
The Nexion Arduino implementation is actually very good code if you look at the sources, but I am probably going to start from scratch and squeeze out every bit of performance now that I understand the code.
The current implementation is a way to attach multiple callback events to a list. But one of my screens the number of buttons will be huge. I have a hunch that the MHI can support about 255 buttons per page.
void NexTouch::iterate(NexTouch **list, uint8_t pid, uint8_t cid, int32_t event)
    NexTouch *e = NULL;
    uint16_t i = 0;
    if (NULL == list)
        return;
    for(i = 0; (e = list[i]) != NULL; i++)
        if (e->getObjPid() == pid && e->getObjCid() == cid)
            e->printObjInfo();
            if (NEX_EVENT_PUSH == event)
                e->push();
            else if (NEX_EVENT_POP == event)
                e->pop();
            break;
 Why would I need 255 buttons? Well imagine that you create touch zones ;-)
So how would I optimize such a thing?
I want one button on one page = only one callback for both button down and button up. This way I can flash jump to that callback instantly without a loop. The HMI sends very compact codes to the Arduino controller.
It is sad that a day does not have 72 hours, I really need more free time :-)
Rich text editor
Olaf Baeyens wrote 08/30/2017 at 16:58 point
Not everything is correct on my posts, it is a learning curve.
Sepio wrote 08/30/2017 at 11:52 point
Nice work. A few days I looked at the Nextion forum. Many people are complaining about the bad or outdated help.  In a couple of weeks I'am also going to use the Nextion Editor and you posts will be a good source of information.
