Test of ART1BOT this time printed in NGEN filament.
It printed without any hiccups on my 3D printer nor warping. It feels very solid and the details are pretty good.
![](https://cdn.hackaday.io/images/9864741510429380644.jpg)
![](https://cdn.hackaday.io/images/5156291510429390788.jpg)
Detail of the cogs
The rim is almost not bendable, and will splinter when pressed to hard.
![](https://cdn.hackaday.io/images/1941961510429358437.jpg)
Bottom part (actually this is the upper part in the Thor robot). You can see that support structures left some fragments behind. The object does have sharp edges, something I did no have when using ABS. But these sharp edges are easier to get rid of wit sand paper. Easier than ABS.
![](https://cdn.hackaday.io/images/5215991510429401154.jpg)
In Cura I like the “concentric” support structure. This can be removed easily.
https://ultimaker.com/en/resources/20422-cura-support-settings
looking good, supports will be a little harder to remove. Use dense in simplify3d and try to make a space between it by adding one layer not printing.
Upper vertical separation layers?
I will try to play with these settings next time... I have a working Sunday day tomorrow
