Mystery why the Nexion Arduino code only reacted on a button release is this:
The button press is triggered by this attach-Push command.
MotorEnable_Z.attachPush(MotorEnable_Callback, &MotorEnable_Z);
The button release is triggered by this attach-Pop command.
MotorEnable_Z.attachPop(MotorEnable_Callback, &MotorEnable_Z);
I took some example code from Nexion and apparently used the Pop (=release button) only
I mistakenly confused it with a LIFO buffer. Push-Pop
Analyzing the Nexion protocol I also discover that it is not wise to use big names as buttons at the HMI implementation. When you request data from the HMI then it sends a big command to the Nexion slowing down the serial communication.
The Nexion Arduino implementation is actually very good code if you look at the sources, but I am probably going to start from scratch and squeeze out every bit of performance now that I understand the code.
The current implementation is a way to attach multiple callback events to a list. But one of my screens the number of buttons will be huge. I have a hunch that the MHI can support about 255 buttons per page.
void NexTouch::iterate(NexTouch **list, uint8_t pid, uint8_t cid, int32_t event)
NexTouch *e = NULL;
uint16_t i = 0;
if (NULL == list)
return;
for(i = 0; (e = list[i]) != NULL; i++)
if (e->getObjPid() == pid && e->getObjCid() == cid)
e->printObjInfo();
if (NEX_EVENT_PUSH == event)
e->push();
else if (NEX_EVENT_POP == event)
e->pop();
break;
Why would I need 255 buttons? Well imagine that you create touch zones ;-)
So how would I optimize such a thing?
I want one button on one page = only one callback for both button down and button up. This way I can flash jump to that callback instantly without a loop. The HMI sends very compact codes to the Arduino controller.
It is sad that a day does not have 72 hours, I really need more free time :-)
Not everything is correct on my posts, it is a learning curve.
Nice work. A few days I looked at the Nextion forum. Many people are complaining about the bad or outdated help. In a couple of weeks I'am also going to use the Nextion Editor and you posts will be a good source of information.
